Zum Hauptinhalt wechseln
Replacing Tungsten E screen. PAL5037
Was du brauchst
  1. Replacing Tungsten E screen. PAL5037, Tungsten E Disassembly: Schritt 1, Bild 1 von 2 Replacing Tungsten E screen. PAL5037, Tungsten E Disassembly: Schritt 1, Bild 2 von 2
    • Remove the stylus and SD card.
    • Using a T5 torx screwdriver, remove all 4 back panel screws.
    • The screws are small and can be lost easily. Be sure to place them in a secure area.
  2. Replacing Tungsten E screen. PAL5037: Schritt 2, Bild 1 von 3 Replacing Tungsten E screen. PAL5037: Schritt 2, Bild 2 von 3 Replacing Tungsten E screen. PAL5037: Schritt 2, Bild 3 von 3
    • Insert a plastic opening tool under the USB and power input slots.
    • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
  3. Replacing Tungsten E screen. PAL5037: Schritt 3, Bild 1 von 2 Replacing Tungsten E screen. PAL5037: Schritt 3, Bild 2 von 2
    • Your device may not have a screen protector. If not, you can move on to step four.
    • Remove the screen protector by lifting the hinge out of the plastic housing.
    • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
  4. Replacing Tungsten E screen. PAL5037: Schritt 4, Bild 1 von 2 Replacing Tungsten E screen. PAL5037: Schritt 4, Bild 2 von 2
    • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
    • Using a spudger, unlock both sides of the flex connector block by pushing down.
    • Remove motherboard completely.
    • Metal washers may pop out of the device during this step
  5. Replacing Tungsten E screen. PAL5037: Schritt 5, Bild 1 von 3 Replacing Tungsten E screen. PAL5037: Schritt 5, Bild 2 von 3 Replacing Tungsten E screen. PAL5037: Schritt 5, Bild 3 von 3
    • Remove buttons using fingers.
    • Gently flex frame to release screen from plastic frame.
    • Lift out screen.
  6. Replacing Tungsten E screen. PAL5037: Schritt 6, Bild 1 von 1
    • Congratulations! You have successfully taken apart a Palm Tungsten E.
  7. Replacing Tungsten E screen. PAL5037, Replacing Touch screen: Schritt 7, Bild 1 von 1
    • Reassemble the device in the reverse order of the tear down using the new screen in place of the old screen.
    • To reconnect the flex connector press up on the blocks with the spudger to ensure they click into place.
    • Be careful not to damage the flex connector.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Kevin Hom
103 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 13-22, Maness Winter 2010 Mitglied von Cal Poly, Team 13-22, Maness Winter 2010
CPSU-MANESS-W10S13G22
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 5,479
