Einleitung
This page is for disassembling the speaker inside the device. Before following these steps, please refer to the Disassembling VTech MobiGo Touch Learning System Case Guide first.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
Remove the eight 6.0 mm JIS #0 case screws.
The speaker will be attached to the back of the case.
Unscrew the two 6.0 mm Philips J0 screws.
Lift the round speaker with a plastic opening tool.
Remove the two wires connected to the speaker.
Once the wires are disconnected, remove the speaker from the back of the case.
Solder the wires to the appropriate spots on the new speaker, making sure that both wires are properly connected.
Insert the new speaker into the hatch located in the middle part of the panel using a plastic spudger.
Once the speaker is properly placed, screw in the two 6.0 mm Philips J0 screws.
To reassemble your case, follow the case instructions in reverse order.
