Zum Hauptinhalt wechseln
Replacing VuPoint DC-ST210-VP View Finder
Was du brauchst
  1. Replacing VuPoint DC-ST210-VP View Finder, Turn Off/Remove Batteries: Schritt 1, Bild 1 von 1
    • Hold the on/off button for 3 seconds until the screen is black.
    • Remove batteries by placing thumb on battery plate cover sliding it down to expose batteries.
    • Turn camera upside down to allow the batteries to fall out.
  2. Replacing VuPoint DC-ST210-VP View Finder, Remove Screws: Schritt 2, Bild 1 von 3 Replacing VuPoint DC-ST210-VP View Finder, Remove Screws: Schritt 2, Bild 2 von 3 Replacing VuPoint DC-ST210-VP View Finder, Remove Screws: Schritt 2, Bild 3 von 3
    • There are 5 (4.5mm in length) screws on the sides of the camera that need to be removed. Use a Phillips #000 screwdriver to remove all screws.
    • Remove 2 screws on the right side of the camera, and store them on a magnetic mat.
    • Remove 2 screws on the bottom of the camera, and store them on a magnetic mat.
    • Remove 1 screw on the left side of the camera, and store it on a magnetic mat.
  3. Replacing VuPoint DC-ST210-VP View Finder, Pry Backplate Off: Schritt 3, Bild 1 von 2 Replacing VuPoint DC-ST210-VP View Finder, Pry Backplate Off: Schritt 3, Bild 2 von 2
    • Using a prying tool or fingernail, gently separate the back plate from the front plate, exposing the inside of the camera.
  4. Replacing VuPoint DC-ST210-VP View Finder, Remove View Finder: Schritt 4, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Use fingers or tweezers to gently lift view finder out of socket.
    • Clean with general lens cleaner and microfiber fabric as necessary and replace.
Abschluss
Dorey Chiu
1 Reputation
1 Anleitung geschrieben
Baylor, Team 8-15, Williams Fall 2014 Mitglied von Baylor, Team 8-15, Williams Fall 2014
BU-WILLIAMS-F14S8G15
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 420
