Zum Hauptinhalt wechseln
Replacing a Bissell POWERforce Helix Vacuum Hose
Was du brauchst
    1. Replacing a Bissell POWERforce Helix Vacuum Hose, Vacuum Hose: Schritt 1, Bild 1 von 1
      • Remove the single 4 mm Phillips screw that attaches the lower hose to the machine.
      Frag FixBot
      Kommentar hinzufügen
    2. Replacing a Bissell POWERforce Helix Vacuum Hose: Schritt 2, Bild 1 von 2 Replacing a Bissell POWERforce Helix Vacuum Hose: Schritt 2, Bild 2 von 2
      • Set the machine on its side to view the access plate and roller assembly.
      Frag FixBot
    3. Replacing a Bissell POWERforce Helix Vacuum Hose: Schritt 3, Bild 1 von 2 Replacing a Bissell POWERforce Helix Vacuum Hose: Schritt 3, Bild 2 von 2
      • Remove the six 4 mm Phillips screws that secure the access plate.
      Frag FixBot
    4. Replacing a Bissell POWERforce Helix Vacuum Hose: Schritt 4, Bild 1 von 3 Replacing a Bissell POWERforce Helix Vacuum Hose: Schritt 4, Bild 2 von 3 Replacing a Bissell POWERforce Helix Vacuum Hose: Schritt 4, Bild 3 von 3
      • Unclip the access plate from the top and bottom.
      • Remove the access plate.
      Frag FixBot
    5. Replacing a Bissell POWERforce Helix Vacuum Hose: Schritt 5, Bild 1 von 2 Replacing a Bissell POWERforce Helix Vacuum Hose: Schritt 5, Bild 2 von 2
      • Lift up the roller assembly and pull it out towards you.
      Frag FixBot
    6. Replacing a Bissell POWERforce Helix Vacuum Hose: Schritt 6, Bild 1 von 2 Replacing a Bissell POWERforce Helix Vacuum Hose: Schritt 6, Bild 2 von 2
      • Detach the black upper hose from the clear lower hose.
      Frag FixBot
    7. Replacing a Bissell POWERforce Helix Vacuum Hose: Schritt 7, Bild 1 von 3 Replacing a Bissell POWERforce Helix Vacuum Hose: Schritt 7, Bild 2 von 3 Replacing a Bissell POWERforce Helix Vacuum Hose: Schritt 7, Bild 3 von 3
      • Remove the lower hose.
      Frag FixBot
    8. Replacing a Bissell POWERforce Helix Vacuum Hose: Schritt 8, Bild 1 von 3 Replacing a Bissell POWERforce Helix Vacuum Hose: Schritt 8, Bild 2 von 3 Replacing a Bissell POWERforce Helix Vacuum Hose: Schritt 8, Bild 3 von 3
      • Detach the upper hose from the machine.
      Frag FixBot
Abschluss
Aidan Hatch
157 Reputation
1 Anleitung geschrieben
UC Davis, Team 2-9, Andersen Winter 2024 Mitglied von UC Davis, Team 2-9, Andersen Winter 2024
UCD-ANDERSEN-W24S2G9
2 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 51
Insgesamt: 944
