Zum Hauptinhalt wechseln
Replacing a Broken/Cracked Window Blind Slat
Was du brauchst
  1. Replacing a Broken/Cracked Window Blind Slat, Window Blind Slat: Schritt 1, Bild 1 von 2 Replacing a Broken/Cracked Window Blind Slat, Window Blind Slat: Schritt 1, Bild 2 von 2
    • Adjust the angle of the blinds until every slat is flat or laying horizontally using the blind's wand.
  2. Replacing a Broken/Cracked Window Blind Slat: Schritt 2, Bild 1 von 3 Replacing a Broken/Cracked Window Blind Slat: Schritt 2, Bild 2 von 3 Replacing a Broken/Cracked Window Blind Slat: Schritt 2, Bild 3 von 3
    • Carefully remove the damaged slat by cutting the slant halfway across its width, at the point where it is connected to the rest of the blind, with a pair of 8-inch 'Westcott' scissors.
    • Remove the damaged slat from the blind after it has been cut on both sides.
  3. Replacing a Broken/Cracked Window Blind Slat: Schritt 3, Bild 1 von 1
    • Choose an un-cracked slat from a part of the blind that is unaffected during normal use - preferably from the very bottom of the blind.
  4. Replacing a Broken/Cracked Window Blind Slat: Schritt 4, Bild 1 von 3 Replacing a Broken/Cracked Window Blind Slat: Schritt 4, Bild 2 von 3 Replacing a Broken/Cracked Window Blind Slat: Schritt 4, Bild 3 von 3
    • Carefully cut the selected slat halfway across its width, at its two connected points.
    • Carefully remove the replacement slat from its old position, making sure to not extend the cut you made past halfway of the slats width.
  5. Replacing a Broken/Cracked Window Blind Slat: Schritt 5, Bild 1 von 3 Replacing a Broken/Cracked Window Blind Slat: Schritt 5, Bild 2 von 3 Replacing a Broken/Cracked Window Blind Slat: Schritt 5, Bild 3 von 3
    • Carefully place the replacement slat it into its new position.
    • Connect the replacement slat to the support strings at the points where the cuts were made.
  6. Replacing a Broken/Cracked Window Blind Slat: Schritt 6, Bild 1 von 3 Replacing a Broken/Cracked Window Blind Slat: Schritt 6, Bild 2 von 3 Replacing a Broken/Cracked Window Blind Slat: Schritt 6, Bild 3 von 3
    • Tear off a small piece of invisible tape from the roll of tape and carefully place it over the cuts that were made on the replacement slat.
    • Apply tape over the top and bottom of the cuts, on both sides of the replacement slat.
  7. Replacing a Broken/Cracked Window Blind Slat: Schritt 7, Bild 1 von 2 Replacing a Broken/Cracked Window Blind Slat: Schritt 7, Bild 2 von 2
    • Twist the wand of the window blind to test it after applying the tape to both sides of the replacement slat.
    • If the replacement slat stays in its new position then congratulations, you have completed the fix!
Abschluss
Moses Matovu
145 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S3-G13, Saloman Spring 2021 Mitglied von UMass Dartmouth, Team S3-G13, Saloman Spring 2021
UMASSD-SALOMAN-S21S3G13
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 44
Letzte 30 Tage: 147
Insgesamt: 5,115
