Einleitung
This guide is intended to show a non expert how to properly replace a broken sprinkler extension. A broad overview of the steps include digging a hole, unscrewing the extension, and replacing the extension. All you need are some basic tools and general knowledge about actions you preform on a daily basis. Before beginning the project, make sure the water is off and check for hazardous insects. Be aware that digging forcefully could damage the pipeline.
Was du brauchst
Dig a one foot wide hole around the broken sprinkler extension down to the pipe fitting.
Clean the area around the fitting with water until the fitting is mostly free of dirt.
If you have completed the steps successfully you should have a fully functioning sprinkler extension.
