Zum Hauptinhalt wechseln
Replacing strings on an All American Bass
Was du brauchst
  1. Replacing strings on an All American Bass, Loosen the tuners. By twisting the peg clockwise.: Schritt 1, Bild 1 von 1
    • Caution: Be careful when working on tensioned strings. Wear protective gear (eyewear, gloves) if possible.
    • Loosen by clockwise.
  2. Replacing strings on an All American Bass, Pull the G-string (the string with the highest pitch) from the peg.: Schritt 2, Bild 1 von 1
    • Can be different per bass.
  3. Replacing strings on an All American Bass, Pull the string from the bridge.: Schritt 3, Bild 1 von 1
    • Pull through the hole near the spring.
  4. Replacing strings on an All American Bass, Count the rivets on the old string to ascertain how many twists are needed.: Schritt 4, Bild 1 von 1
    • This can be done by counting the rivets in old string.
  5. Replacing strings on an All American Bass, Thread the new strings through the bridge over the groove.: Schritt 5, Bild 1 von 1
    • Reverse Step 4.
  6. Replacing strings on an All American Bass, Pull the string up to the tuner head and place it in-to the hole.: Schritt 6, Bild 1 von 1
    • CAUTION: Can lead to string snapping and hurting one self.
  7. Replacing strings on an All American Bass, Wrap the string around the tuner peg counter-clockwise.: Schritt 7, Bild 1 von 1
  8. Replacing strings on an All American Bass, Tighten the string by twisting the peg counter-clockwise.: Schritt 8, Bild 1 von 1
  9. Replacing strings on an All American Bass, Hold the end of the tuner and turn the peg until the bass has been suitably tuned.: Schritt 9, Bild 1 von 1
    • Use a phone tuner or regular guitar tuner.
  10. Replacing strings on an All American Bass, Repeat steps 1-9 for all re-maining strings.: Schritt 10, Bild 1 von 1
    • You're Done!
Abschluss
Your bass should now be restrung correctly and ready to rock out.
Eine weitere Person hat diese Anleitung absolviert.
Jeffrey Baston
1 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 203
