Zum Hauptinhalt wechseln
Einleitung
How to remove and replace the hard drive.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the 7 mm Phillips #0 screws.
    • Remove the 7 mm Phillips #0 screws.
    • Remove the 10 mm Phillips #0 screws.
    • Remove the 14 mm Phillips #0 screw.
  2. Open the flap on the left hand side. Open the flap on the left hand side.
    • Open the flap on the left hand side.
  3. Insert the plastic opening tools between the right and left sides of the latch. Pry the right side  of the latch, and then pry the left side to detach the laptop's cover.
    • Insert the plastic opening tools between the right and left sides of the latch.
    • Pry the right side of the latch, and then pry the left side to detach the laptop's cover.
  4. Open the flap on the right side. Open the flap on the right side.
    • Open the flap on the right side.
  5. Insert the plastic opening tools towards the right side of the latch.
    • Insert the plastic opening tools towards the right side of the latch.
    • Gently pry the right side out to release the top cover.
  6. Lift the keyboard slowly. A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
    • Lift the keyboard slowly.
    • A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
  7. Use your fingers or a spudger to detach the connector.
    • Use your fingers or a spudger to detach the connector.
  8. Carefully lift and remove the keyboard. Carefully lift and remove the keyboard.
    • Carefully lift and remove the keyboard.
  9. On the back of the computer, use a Flathead screwdriver to remove this lone screw.
    • On the back of the computer, use a Flathead screwdriver to remove this lone screw.
  10. After the screw is out, gently remove the cover. After the screw is out, gently remove the cover.
    • After the screw is out, gently remove the cover.
  11. Turn the computer back over so the hard drive faces up. Remove the shown screw with a Phillips screwdriver. Turn the computer back over so the hard drive faces up. Remove the shown screw with a Phillips screwdriver. Turn the computer back over so the hard drive faces up. Remove the shown screw with a Phillips screwdriver.
    • Turn the computer back over so the hard drive faces up. Remove the shown screw with a Phillips screwdriver.
  12. Make sure you are grounded and detach the IDA cable connecting the hard disk to the motherboard.
    • Make sure you are grounded and detach the IDA cable connecting the hard disk to the motherboard.
  13. Remove the final two screws (shown) and slide out the hard drive. Remove the final two screws (shown) and slide out the hard drive.
    • Remove the final two screws (shown) and slide out the hard drive.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Derek Driscoll
119 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 26-27, Regan Spring 2010 Mitglied von Cal Poly, Team 26-27, Regan Spring 2010
CPSU-REGAN-S10S26G27
3 Mitglieder
18 Anleitungen geschrieben
You don't have to go to this length to remove the hard drive on a 560Z. Only do steps 0 (remove battery), 9 (remove screw) and 10 (remove cover). Then simply grab the blue tab of the hard drive caddy and pull the drive out of the bay. Complete directions on maintenance of the IBM Thinkpad 560Z can be found here:
http://www.thinkpads.com/support/hmm/hmm...
The Hardware Maintenance Manual has all of the information you need to take a 560Z apart and put it back together.
The procedure outlined here is similar to what the 560, 560E and 560X systems required; the 560Z is totally different when removing the hard drive.
Raymond - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 2,797
