Was du brauchst
Torx #2
Pry in between the screen and the back cover. All electronic components are on the back of the screen.
Remove the battery, lower PCB and screen connector bracket. Use a Philips #0 screwdriver.
Screen connector
Follow these instructions in reverse order to reassemble your device.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
