Was du brauchst
Unlock the battery latch on the right.
Unlock the battery lock on the left.
Remove the battery pack from its slot.
Using the Philips # 0 screwdriver, unscrew the 2 screws of the top cover
Check the marks indicating the direction in which the cover must be removed.
Remove the bottom cover by removing it in the direction of the markers.
This is the SSD drive
Unscrew the fixing screw of the SSD using the Philips # 0 screwdriver.
Remove the SSD.
For reassembly, follow the instructions in reverse order.
100%
irlanda hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
