Einleitung
This tutorial allows you to replace the air filter of your Citroen C1 | 1.0 fuel.
Equally useful for the Peugeot 107 and the Toyota Aygo, the three vehicles communicate on the same platform and the same 1.0 fuel motor.
Was du brauchst
Open the hood of your C1 by finding the lever located under the steering wheel to the left and pulling it.
Identify the air filter box.
Remove the hooks to detach the air filter box.
Loosen the collar and reassemble it to free the sleeve.
Loosen the collar of the air intake pipe.
Remove the air filter from its housing.
You can now install the new air filter.
To reassemble the air filter box, follow the instructions in reverse order.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
