Zum Hauptinhalt wechseln
ResMed AirSense 10 Wireless Communication Board Replacement
Medizinische Ausrüstung
Weder iFixit noch diese Reparaturanleitung werden vom Hersteller medizinischer Geräte unterstützt oder sind mit diesem verbunden.
Was du brauchst
  1. ResMed AirSense 10 Wireless Communication Board Replacement, Top Cover: Schritt 1, Bild 1 von 2 ResMed AirSense 10 Wireless Communication Board Replacement, Top Cover: Schritt 1, Bild 2 von 2
    • Remove the water tub by gently pulling it out.
    Frag FixBot
    Kommentar hinzufügen
  2. ResMed AirSense 10 Wireless Communication Board Replacement: Schritt 2, Bild 1 von 3 ResMed AirSense 10 Wireless Communication Board Replacement: Schritt 2, Bild 2 von 3 ResMed AirSense 10 Wireless Communication Board Replacement: Schritt 2, Bild 3 von 3
    • Pry off the face plate by using your finger or an opening tool.
    • Use a moderate amount of force when prying open.
    • Remove the face plate from the top cover.
    • There will be a clicking sound on either side of the divot when assembling and disassembling.
    Frag FixBot
  3. ResMed AirSense 10 Wireless Communication Board Replacement: Schritt 3, Bild 1 von 2 ResMed AirSense 10 Wireless Communication Board Replacement: Schritt 3, Bild 2 von 2
    • Unscrew and remove the two 11.8 mm TR10 Torx screws that were revealed from the face plate being removed.
    Frag FixBot
  4. ResMed AirSense 10 Wireless Communication Board Replacement: Schritt 4, Bild 1 von 2 ResMed AirSense 10 Wireless Communication Board Replacement: Schritt 4, Bild 2 von 2
    • Unscrew and remove the two 11.8 mm TR10 Torx screws from the bottom of the device.
    Frag FixBot
  5. ResMed AirSense 10 Wireless Communication Board Replacement: Schritt 5, Bild 1 von 3 ResMed AirSense 10 Wireless Communication Board Replacement: Schritt 5, Bild 2 von 3 ResMed AirSense 10 Wireless Communication Board Replacement: Schritt 5, Bild 3 von 3
    • Remove the top cover from the rest of the device.
    Frag FixBot
  6. ResMed AirSense 10 Wireless Communication Board Replacement, Wireless Communication Board: Schritt 6, Bild 1 von 3 ResMed AirSense 10 Wireless Communication Board Replacement, Wireless Communication Board: Schritt 6, Bild 2 von 3 ResMed AirSense 10 Wireless Communication Board Replacement, Wireless Communication Board: Schritt 6, Bild 3 von 3
    • Place a halberd spudger behind the connector cable.
    • Use a halberd spudger to pull the connector away from the motherboard.
    Frag FixBot
  7. ResMed AirSense 10 Wireless Communication Board Replacement: Schritt 7, Bild 1 von 2 ResMed AirSense 10 Wireless Communication Board Replacement: Schritt 7, Bild 2 von 2
    Frag FixBot
  8. ResMed AirSense 10 Wireless Communication Board Replacement: Schritt 8, Bild 1 von 2 ResMed AirSense 10 Wireless Communication Board Replacement: Schritt 8, Bild 2 von 2
    • Insert a plastic opening tool in between the side and bottom panel.
    • Pry the side panel away from the bottom panel with the plastic opening tool.
    • Remove the side panel by pulling it away from the device.
    Frag FixBot
  9. ResMed AirSense 10 Wireless Communication Board Replacement: Schritt 9, Bild 1 von 2 ResMed AirSense 10 Wireless Communication Board Replacement: Schritt 9, Bild 2 von 2
    • Push in the clips which secure the board to the side panel with the plastic opening tool.
    Frag FixBot
  10. ResMed AirSense 10 Wireless Communication Board Replacement: Schritt 10, Bild 1 von 2 ResMed AirSense 10 Wireless Communication Board Replacement: Schritt 10, Bild 2 von 2
    • Remove the wireless communication board from the side panel.
    Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
4 Kommentare zur Anleitung
I have an early ResMed Airsense 10 and my wireless comm board was 3G. Can this be updated with a replacement board?
Lynd Mccormick - Antwort Teilen
The wires came out of the moden connector at the board were do I get a replacement wire?
Carl R - Antwort Teilen
Any luck finding one? I have the same issue.
Scott kiefert - Antwort Teilen
The premise that "the device is having internet or network issues" is not based on anything factual. These machines are cellular network based.
Earl - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 26
Letzte 30 Tage: 127
Insgesamt: 3,318
