Einleitung
This guide will take you through the process required to reset your Netgear router.
Was du brauchst
Rotate device so the back panel is facing you.
Locate the reset button. It is located on the metal grating next to the antenna.
Push the reset button using a tool, along the lines of a pencil or paper clip, until you hear the button click.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
