Zum Hauptinhalt wechseln
Resetting the Palm m105
Was du brauchst
  1. Resetting the Palm m105, Device Reset: Schritt 1, Bild 1 von 1
    • To soft reset the device, use a paperclip to carefully press the reset button located on the back of the device. The exact location of the button can be seen in the picture.
    • A soft reset means that it will usually not affect your personal data on your device, unless the batteries are low.
    • After you press the button, the device will reboot as if you just powered on your device and it should clear up most common device problems.
    • If your device is still not powering up or has a blank display, the next step will help you perform a hard reset of the device.
  2. Resetting the Palm m105: Schritt 2, Bild 1 von 2 Resetting the Palm m105: Schritt 2, Bild 2 von 2
    • A hard reset will erase all current data on the device. This should only be done if a soft reset has not solved your problem.
    • A hard reset is done by simultaneously holding down the power button while also pressing the reset button on the back with a paper clip like you did for the soft reset. After a few seconds the Palm logo should appear, when it does, release the power button.
    • If applicable, you can restore any data previously synchronized with your PC through the HotSync operation of the device.
Abschluss
Erik Thompson
31 Reputation
5 Anleitungen geschrieben
UW Stout, Team 1-3, Zhou Fall 2011 Mitglied von UW Stout, Team 1-3, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G3
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 16
Insgesamt: 1,383
