Zum Hauptinhalt wechseln
Resetting the System Management Controller (SMC) on your Mac
      • Try each of the following steps in the order listed before resetting the SMC. Check after each troubleshooting step if the issue still persists.
      • If your Mac isn't responding, force shut it down by pressing and holding the power button for 10 seconds. Any unsaved data in open applications will however be lost.
      • Press Command+Option+Esc to force quit any unresponsive app.
      • Put your Mac in sleep mode by choosing Sleep from the Apple menu. Wake the computer after it went to sleep mode.
      • Restart your Mac by choosing Restart from the Apple menu.
      • Shut down your Mac by choosing Shut Down from the Apple menu, then turn it back on.
      Frag FixBot
      Kommentar hinzufügen
      • If you're using a Mac laptop that's having power or battery issues, follow these steps:
      • Unplug the Mac's power adapter and power outlet for a few seconds, then plug them back in.
      • Shut down your Mac.
      • Remove and reinsert the battery (if removable).
      • Restart your Mac.
      Frag FixBot
Ziellinie
5 weitere Personen haben diese Anleitung absolviert.
fr en
100%
Hier starten ›
2 Kommentare zur Anleitung
Thank you a lot
Ola Agboola - Antwort Teilen
Salut bon j’ai un souci avec mon ordinateur mac book pro mi 2012
Si je rallume mon ordinateur à 1 ou 2 minutes il planque et j’entends un bruit à l’intérieur
J’aimerais savoir d’où vient le problème
Mor Gueye - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 28
Letzte 30 Tage: 116
Insgesamt: 5,258
