Einleitung
Use this guide to replace a faulty gas cylinder in your Respawn RSP-110 Gaming Chair.
Gas cylinders adjust the seat height in wheeled office and gaming chairs to the user's desired level. However, these chairs may sink over time and not remain at the same level. If you notice your chair not maintaining its height, you can replace its gas cylinder.
Since this process requires using a mallet, take special care not to hurt yourself.
Was du brauchst
Below the seat, push the lift lever up to extend the chair to its full capacity.
To the left of the lift lever, push the lock lever up to ensure the backrest is vertical.
Get your new gas cylinder.
Attach the cylinder to the underside of the seat, and twist counterclockwise.
Place the bottom of the cylinder into the chair base and twist to lock it just enough to safely stand it upright
Stand the chair upright.
Place your knee on the seat and hold the armrests.
Apply pressure on the middle of the seat to ensure that the cylinder is locked in place.
You've successfully replaced the gas cylinder on your chair!
