Was du brauchst
Place the device face down.
Use a T15 Torx screwdriver to remove the six screws in the base plate.
Lift the base plate off of the device.
Flip the circuit board over to the right.
Gently pull the ribbon cable outward to disconnect it from the circuit board.
Disconnect the red 3-wire plug at the top left of the board and the white 4-wire plug at the bottom left.
Remove the circuit board.
2 Kommentare
Where to find a power supply circuit board for my Remstar plus m series which just blinks blue lights. dledes@shaw.ca
