Zum Hauptinhalt wechseln
Respironics REMstar Plus M Series Power Supply Circuit board Replacement
Was du brauchst
  1. Respironics REMstar Plus M Series Power Supply Circuit board Replacement, Power Supply Circuit board: Schritt 1, Bild 1 von 3 Respironics REMstar Plus M Series Power Supply Circuit board Replacement, Power Supply Circuit board: Schritt 1, Bild 2 von 3 Respironics REMstar Plus M Series Power Supply Circuit board Replacement, Power Supply Circuit board: Schritt 1, Bild 3 von 3
    • Place the device face down.
    • Use a T15 Torx screwdriver to remove the six screws in the base plate.
    • Lift the base plate off of the device.
  2. Respironics REMstar Plus M Series Power Supply Circuit board Replacement: Schritt 2, Bild 1 von 3 Respironics REMstar Plus M Series Power Supply Circuit board Replacement: Schritt 2, Bild 2 von 3 Respironics REMstar Plus M Series Power Supply Circuit board Replacement: Schritt 2, Bild 3 von 3
    • Flip the circuit board over to the right.
    • Gently pull the ribbon cable outward to disconnect it from the circuit board.
  3. Respironics REMstar Plus M Series Power Supply Circuit board Replacement: Schritt 3, Bild 1 von 2 Respironics REMstar Plus M Series Power Supply Circuit board Replacement: Schritt 3, Bild 2 von 2
    • Disconnect the red 3-wire plug at the top left of the board and the white 4-wire plug at the bottom left.
    • Remove the circuit board.
Abschluss
2 Kommentare
My unit stops working in the middle of the night, then beeps, & blue light flashes. Will replacing this board fix this, and where can I get one?
mert454 - Antwort
Where to find a power supply circuit board for my Remstar plus m series which just blinks blue lights. dledes@shaw.ca
David Edes - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 954
