Einleitung
If your controller(s) malfunction, you can replace the circuit boards. You only need a Phillips #1 screwdriver.
Was du brauchst
With the controller on its face, remove the five 6 mm Phillips #1 screws.
After removing the screws, carefully lift the controller casing .
Pinch the top and bottom of the shoulder buttons and lift them out.
Below each shoulder button, there are small elastic pads. To remove them, pinch the pads and slide them out.
Abschluss
