Zum Hauptinhalt wechseln
Retro-Bit Retro Duo Controller Button and Pad Replacement.
Was du brauchst
  1. Retro-Bit Retro Duo Controller Button and Pad Replacement., Buttons and Pads in Controller(s): Schritt 1, Bild 1 von 3 Retro-Bit Retro Duo Controller Button and Pad Replacement., Buttons and Pads in Controller(s): Schritt 1, Bild 2 von 3 Retro-Bit Retro Duo Controller Button and Pad Replacement., Buttons and Pads in Controller(s): Schritt 1, Bild 3 von 3
    • With the controller on its face, remove the five 6 mm Phillips #1 screws.
    • After screw removal, carefully lift the controller casing.
  2. Retro-Bit Retro Duo Controller Button and Pad Replacement.: Schritt 2, Bild 1 von 3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: Schritt 2, Bild 2 von 3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: Schritt 2, Bild 3 von 3
    • Pinch the top and bottom of the shoulder pads, then lift out.
    • There are small elastic pads below each shoulder pad. Replace these if they are not functioning correctly.
  3. Retro-Bit Retro Duo Controller Button and Pad Replacement.: Schritt 3, Bild 1 von 3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: Schritt 3, Bild 2 von 3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: Schritt 3, Bild 3 von 3
    • Carefully lift the circuit board from the controller case.
  4. Retro-Bit Retro Duo Controller Button and Pad Replacement.: Schritt 4, Bild 1 von 3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: Schritt 4, Bild 2 von 3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: Schritt 4, Bild 3 von 3
    • To replace the action button pad, lift this part out.
    • Lift the Select and Start button pad.
    • If replacing the D-Pad, lift this pad.
    • Pinch and lift the shoulder button pads.
  5. Retro-Bit Retro Duo Controller Button and Pad Replacement.: Schritt 5, Bild 1 von 3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: Schritt 5, Bild 2 von 3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: Schritt 5, Bild 3 von 3
    • Support the controller face and push buttons toward the inner case.
    • Use care. The buttons have a tiny tab to keep them in place.
    • Support the controller face and push the D-Pad toward the inner case.
Abschluss
Evelyn
223 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S4-G4, Eyestone Fall 2017 Mitglied von USF Tampa, Team S4-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S4G4
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 1,169
