Einleitung
If the reset button and/or power switch get stuck or physically broken, they can be replaced using Phillips #0 and #2 screwdrivers.
Was du brauchst
With the console on its top. Remove the four 12 mm Phillips #2 screws.
Flip the console on its feet and carefully lift the top casing from the back (where the AV/S and power ports are).
Using your fingers (or precision tweezers), carefully pinch the button tabs and push through to the other side.
If the problem persists after the buttons are replaced, it may be a circuit board issue. If so, please visit our guide for circuit board replacement at Retro-Bit Retro Duo Circuit Board Replacement
