Zum Hauptinhalt wechseln
RetroMini Miyoo Mini Plus Battery Replacement
Was du brauchst
  1. RetroMini Miyoo Mini Plus Battery Replacement, Battery: Schritt 1, Bild 1 von 2 RetroMini Miyoo Mini Plus Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Lay the device face down on a flat surface.
    • You may want to lay the device on a towel or other soft surface to avoid scratching the screen.
    Frag FixBot
    Kommentar hinzufügen
  2. RetroMini Miyoo Mini Plus Battery Replacement: Schritt 2, Bild 1 von 2 RetroMini Miyoo Mini Plus Battery Replacement: Schritt 2, Bild 2 von 2
    • Use your fingernail to push in the battery compartment tab.
    • Lift the cover up to expose the battery.
    Frag FixBot
  3. RetroMini Miyoo Mini Plus Battery Replacement: Schritt 3, Bild 1 von 1
    • Use an opening tool to gently lift the the battery from its compartment.
    • Gently pull the battery out and set the battery next to the system, with care not to strain the attached wire.
    Frag FixBot
  4. RetroMini Miyoo Mini Plus Battery Replacement: Schritt 4, Bild 1 von 2 RetroMini Miyoo Mini Plus Battery Replacement: Schritt 4, Bild 2 von 2
    • Pinch the white battery connector and pull it directly out of its socket.
    • Completely remove the battery.
    Frag FixBot
  5. RetroMini Miyoo Mini Plus Battery Replacement: Schritt 5, Bild 1 von 2 RetroMini Miyoo Mini Plus Battery Replacement: Schritt 5, Bild 2 von 2
    • When you have the new battery, put the new battery wire into the connecter.
    • Place the battery back into the empty space with the wire at the bottom of the battery.
    Frag FixBot
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
Eine weitere Person hat diese Anleitung absolviert.
Kaden
599 Reputation
4 Anleitungen geschrieben
1 Kommentar zur Anleitung
Does anyone know where to get these batteries? Or perhaps the specs of the Miyoo Mini Plus battery such as dimensions (mine is a bit obese right now) and connector type?
Arend Hamming - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 68
Letzte 30 Tage: 287
Insgesamt: 2,313
