Einleitung
If the shell of your Retro Mini Miyoo Plus breaks in some manner, use this guide to transfer all of the parts into a new casing for further use.
Was du brauchst
Use your fingernail to push in the battery compartment tab.
Lift the cover up to expose the battery.
Use an opening tool to gently lift the the battery from its compartment.
Gently pull the battery out and set the battery next to the system, with care not to strain the attached wire.
Pinch the white battery connector and pull it directly out of its socket.
Completely remove the battery.
When you have the new battery, put the new battery wire into the connecter.
Place the battery back into the empty space with the wire at the bottom of the battery.
Remove the four screws securing the rear case with a Phillips screwdriver.
Remove the two Phillips screws inside the battery compartment.
Insert an opening tool into the seam between the front and rear case.
Pry the front and rear case apart.
Gently set the rear case aside.
Make sure you lift the black tab on the left side of the motherboard and gently remove the ribbon cable as to not damage it when removing the motherboard from the case.
Heat an iOpener according to the instructions here.
Rest the iOpener Gel Bag on the screen for a minute.
Gently apply pressure to the highlighted area on the front cover of the device.
While applying the pressure gently peel the screen off of the device.
Heat up the IFixit IOpener Gel Bag for 30 seconds once again.
Once heated, rest the IFixit IOpener Gel Bag on the bottom of the device for a minute.
Repeat this step if the glue holding the speakers on has not melted.
Gently wedge an opening between the shell and the speakers and lift up.
Place the speakers off to the side once both are removed.
