Zum Hauptinhalt wechseln
Retroid Pocket 3 Button Pad Replacement
Was du brauchst
  1. Retroid Pocket 3 Button Pad Replacement, Battery: Schritt 1, Bild 1 von 1
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
  2. Retroid Pocket 3 Button Pad Replacement: Schritt 2, Bild 1 von 3 Retroid Pocket 3 Button Pad Replacement: Schritt 2, Bild 2 von 3 Retroid Pocket 3 Button Pad Replacement: Schritt 2, Bild 3 von 3
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
  3. Retroid Pocket 3 Button Pad Replacement: Schritt 3, Bild 1 von 2 Retroid Pocket 3 Button Pad Replacement: Schritt 3, Bild 2 von 2
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
  4. Retroid Pocket 3 Button Pad Replacement: Schritt 4, Bild 1 von 3 Retroid Pocket 3 Button Pad Replacement: Schritt 4, Bild 2 von 3 Retroid Pocket 3 Button Pad Replacement: Schritt 4, Bild 3 von 3
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
  5. Retroid Pocket 3 Button Pad Replacement, Button Pad: Schritt 5, Bild 1 von 3 Retroid Pocket 3 Button Pad Replacement, Button Pad: Schritt 5, Bild 2 von 3 Retroid Pocket 3 Button Pad Replacement, Button Pad: Schritt 5, Bild 3 von 3
    • Undo the ribbon cable clips using the Spudger tool.
    • Unclip the cable on the left side of the board.
    • Carefully lift the ribbon cable to the right to remove it from the clip.
  6. Retroid Pocket 3 Button Pad Replacement: Schritt 6, Bild 1 von 2 Retroid Pocket 3 Button Pad Replacement: Schritt 6, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the three 5.9 mm screws from the controller board.
    • Carefully lift the board out of the device.
  7. Retroid Pocket 3 Button Pad Replacement: Schritt 7, Bild 1 von 2 Retroid Pocket 3 Button Pad Replacement: Schritt 7, Bild 2 von 2
    • Using the Spudger tool, put the tip under the edge of the rubber button pad to start lifting it.
    • Button pad will loosen and lift straight out of the casing.
  8. Retroid Pocket 3 Button Pad Replacement: Schritt 8, Bild 1 von 1
    • Move to the right side of the device.
    • Using a spudger, undo the ribbon cable clip connected to the main PCB along with the joystick ribbon cable.
  9. Retroid Pocket 3 Button Pad Replacement: Schritt 9, Bild 1 von 3 Retroid Pocket 3 Button Pad Replacement: Schritt 9, Bild 2 von 3 Retroid Pocket 3 Button Pad Replacement: Schritt 9, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove the two 5.9 mm screws.
  10. Retroid Pocket 3 Button Pad Replacement: Schritt 10, Bild 1 von 3 Retroid Pocket 3 Button Pad Replacement: Schritt 10, Bild 2 von 3 Retroid Pocket 3 Button Pad Replacement: Schritt 10, Bild 3 von 3
    • Carefully pry up the silicone button pad with a Spudger tool.
Abschluss
Cassidy Anderson
241 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 9
Letzte 30 Tage: 38
Insgesamt: 77
