Zum Hauptinhalt wechseln
Retroid Pocket 3 Motherboard Replacement
Was du brauchst
  1. Retroid Pocket 3 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
  2. Retroid Pocket 3 Motherboard Replacement: Schritt 2, Bild 1 von 3 Retroid Pocket 3 Motherboard Replacement: Schritt 2, Bild 2 von 3 Retroid Pocket 3 Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
  3. Retroid Pocket 3 Motherboard Replacement: Schritt 3, Bild 1 von 2 Retroid Pocket 3 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
  4. Retroid Pocket 3 Motherboard Replacement: Schritt 4, Bild 1 von 3 Retroid Pocket 3 Motherboard Replacement: Schritt 4, Bild 2 von 3 Retroid Pocket 3 Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
  5. Retroid Pocket 3 Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 1
    • Remove the three 4.5 mm screws with a Phillips #00 screwdriver on the main board.
  6. Retroid Pocket 3 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Using a spudger, put the tip under the aerial connecter and rotate upwards to unclip the plug.
  7. Retroid Pocket 3 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Unclip and remove the one ribbon cable on the left.
  8. Retroid Pocket 3 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Use a spudger to unclip and remove the two ribbon cables on the right side.
  9. Retroid Pocket 3 Motherboard Replacement: Schritt 9, Bild 1 von 2 Retroid Pocket 3 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Use a spudger to disconnect the two speaker cables on the bottom of the board.
  10. Retroid Pocket 3 Motherboard Replacement: Schritt 10, Bild 1 von 3 Retroid Pocket 3 Motherboard Replacement: Schritt 10, Bild 2 von 3 Retroid Pocket 3 Motherboard Replacement: Schritt 10, Bild 3 von 3
    • Start lifting the board to give you access to the vibration motor on the metal case.
    • Use a spudger to carefully pry the motor free; it is bound with double-sided tape.
    • Carefully lift the board out of the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 20
Insgesamt: 58
