Einleitung
If the device is not turning on at all and is not responding, follow this guide to do a mainboard replacement (PCB) on the device. This process will take approximately 20-25 minutes, and the tools needed for the project are listed in the guide.
Was du brauchst
Unplug any cables connected to the Retroid Pocket 3+.
Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
Lift off the metal plate.
Use a plastic opening tool or spudger to unclip the battery connector.
Carefully lift the battery from the case.
Lift and remove the battery.
Remove the three 4.5 mm screws with a Phillips #00 screwdriver on the main board.
Using a spudger, put the tip under the aerial connecter and rotate upwards to unclip the plug.
Start lifting the board to give you access to the vibration motor on the metal case.
Use a spudger to carefully pry the motor free; it is bound with double-sided tape.
Carefully lift the board out of the device.
