Zum Hauptinhalt wechseln
Reupholstering a Couch Cushion
Was du brauchst
    1. Reupholstering a Couch Cushion, Couch Upholstery: Schritt 1, Bild 1 von 3 Reupholstering a Couch Cushion, Couch Upholstery: Schritt 1, Bild 2 von 3 Reupholstering a Couch Cushion, Couch Upholstery: Schritt 1, Bild 3 von 3
      • Remove the cushion from the couch. This will easily insure you to get the proper measurements of the cushion.
      Frag FixBot
      Kommentar hinzufügen
    2. Reupholstering a Couch Cushion: Schritt 2, Bild 1 von 3 Reupholstering a Couch Cushion: Schritt 2, Bild 2 von 3 Reupholstering a Couch Cushion: Schritt 2, Bild 3 von 3
      • Using a tape measure, measure the height, width, and length the cushion.
      Frag FixBot
    3. Reupholstering a Couch Cushion: Schritt 3, Bild 1 von 2 Reupholstering a Couch Cushion: Schritt 3, Bild 2 von 2
      • Replace the cushion with a new cushion.
      • In my case, I added a layer of new memory foam on the top and bottom of the existing cushion.
      Frag FixBot
    4. Reupholstering a Couch Cushion: Schritt 4, Bild 1 von 1
      • Draw out the measurements on the new fabric.
      • Take the measurements you gathered from Step 2 and measure/draw it on the new fabric to accurately cut the the fabric.
      Frag FixBot
    5. Reupholstering a Couch Cushion: Schritt 5, Bild 1 von 2 Reupholstering a Couch Cushion: Schritt 5, Bild 2 von 2
      • Cut new fabric along your designated measurement lines.
      • Iron the newly cut fabric to prevent any wrinkles. This will help make for a more smooth and easy process.
      Frag FixBot
    6. Reupholstering a Couch Cushion: Schritt 6, Bild 1 von 1
      • Cover the cushion with the fabric
      Frag FixBot
    7. Reupholstering a Couch Cushion: Schritt 7, Bild 1 von 2 Reupholstering a Couch Cushion: Schritt 7, Bild 2 von 2
      • Staple the fabric onto the cushion so it is secure enough that it will not come loose.
      • Once this step is completed, your cushion is all done and ready to be put back onto your couch!
      • If you would prefer: another way to secure the fabric around the cushion would be the sew it!
      Frag FixBot
    8. Reupholstering a Couch Cushion: Schritt 8, Bild 1 von 1
      • Final product!
      Frag FixBot
Abschluss
To reupholster your cushion, follow these instructions:
1. Remove the cushion(s) from the couch.
This will easily insure you to get the proper measurements of the cushion(s).
2. Using a tape measure, measure the height, width, and length of the cushion(s).
3. Replace the cushion with new cushion.
*In my case, I added a layer of new memory foam to the top and bottom of the existing cushion.
4. Draw out the measurements on the new fabric.
5. Cut and iron the new fabric to prevent any wrinkles. *This will help make for a more smooth and easy process.
6. Cover the cushion with the fabric
7. Staple the fabric onto the cushion so it is secure enough that it won’t come loose.
Eine weitere Person hat diese Anleitung absolviert.
Tiffany St.Lifer
187 Reputation
1 Anleitung geschrieben
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020 Mitglied von USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020
USFSM-STEWART-S20S1G1
23 Mitglieder
99 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 17
Letzte 30 Tage: 72
Insgesamt: 5,828
