Einleitung
After long term use of the Revlon One-Step Hair dryer, the filter may become blocked with debris which could result in limited airflow. Therefore, this guide will help users to replace the lint filter.
Was du brauchst
First, remove the pink panels on each side of the handle in order to access the screws.
After removing the pink panels, there will be one visible screw on each side of the dryer handle measuring at 11mm.
Carefully unscrew both of these screws with a tri-point Y000 screwdriver.
Next, completely remove the screws out of the dryer handle.
Remove the barrel by twisting and pulling it away from the handle of the dryer.
Next, slide down the air inlet and the setting dial to reveal the 11mm screws on each side of the handle at the bottom of the hair dryer.
There will be one visible screw on each side of the dryer at the bottom of the handle, measuring at 11mm.
Place the iFixit opening tool along the seams of the handle and pry the two pieces apart.
Once you have exposed the inside of the dryer, you will see a clear port at the very end where the cord is connected and plugged into.
Now, with your thumb and pointer finger gently pinch the top and bottom of the clear port.
Next with your free hand carefully pull the cord out of the port of the dryer handle.
Once the cord is disconnected from the handle, you should be able to slide the dial setting off completely and free it from the cord.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
I' just fixed mine following your instructions.. Thanks a lot for the share.
