Zum Hauptinhalt wechseln
Ricoh Shotmaster 130Z Battery Replacement
Was du brauchst
  1. Ricoh Shotmaster 130Z Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • First, make sure that the camera is turned off. The dial must line up the word "off" with the white tally mark.
  2. Ricoh Shotmaster 130Z Battery Replacement: Schritt 2, Bild 1 von 2 Ricoh Shotmaster 130Z Battery Replacement: Schritt 2, Bild 2 von 2
    • You can find the battery compartment on the side of the camera. Search for the arrow and the abreviation "BATT"
    • Stick your finger nail (or a blue opening tool if you wish) in the notch and flip open the door to expose the battery compartment.
  3. Ricoh Shotmaster 130Z Battery Replacement: Schritt 3, Bild 1 von 3 Ricoh Shotmaster 130Z Battery Replacement: Schritt 3, Bild 2 von 3 Ricoh Shotmaster 130Z Battery Replacement: Schritt 3, Bild 3 von 3
    • The yellow latch holds down an extra cover for the batteries
    • Push on it in to open the compartment
    • Insert batteries according to the charges marked on the inside part of the cover
Abschluss
tcalvin12
153 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 3-4, Isaacson Fall 2016 Mitglied von UMass Dartmouth, Team 3-4, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G4
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 672
