Zum Hauptinhalt wechseln
Ricoh Super 8 800z Eyepiece Adjuster Replacement
Was du brauchst
  1. Ricoh Super 8 800z Eyepiece Adjuster Replacement, Eyepiece Adjuster: Schritt 1, Bild 1 von 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement, Eyepiece Adjuster: Schritt 1, Bild 2 von 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement, Eyepiece Adjuster: Schritt 1, Bild 3 von 3
    • Remove the rubber covering from the eyepiece by slowly pulling down on the cover from any direction.
  2. Ricoh Super 8 800z Eyepiece Adjuster Replacement: Schritt 2, Bild 1 von 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: Schritt 2, Bild 2 von 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: Schritt 2, Bild 3 von 3
    • Use Phillips #000 screwdriver to remove the three screws around the eyepiece lens.
    • Remove the metal plate from the eyepiece.
  3. Ricoh Super 8 800z Eyepiece Adjuster Replacement: Schritt 3, Bild 1 von 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: Schritt 3, Bild 2 von 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: Schritt 3, Bild 3 von 3
    • Turn the adjustment ring counter clockwise until it is as close to the lens as it will go.
  4. Ricoh Super 8 800z Eyepiece Adjuster Replacement: Schritt 4, Bild 1 von 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: Schritt 4, Bild 2 von 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: Schritt 4, Bild 3 von 3
    • Remove the screw on top of the back panel of the camera using a Phillips #000 screwdriver.
    • Use a plastic opening tool to lift the plastic covering to reveal a screw underneath it.
  5. Ricoh Super 8 800z Eyepiece Adjuster Replacement: Schritt 5, Bild 1 von 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: Schritt 5, Bild 2 von 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: Schritt 5, Bild 3 von 3
    • Continue to hold the plastic covering back with the plastic opening tool.
    • Use a #1 flathead screwdriver to remove screw in the oval opening beside the eyepiece. Be careful not to drop the screw into the camera body.
  6. Ricoh Super 8 800z Eyepiece Adjuster Replacement: Schritt 6, Bild 1 von 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: Schritt 6, Bild 2 von 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: Schritt 6, Bild 3 von 3
    • Slide the eyepiece adjuster out of the camera body.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 282
