Zum Hauptinhalt wechseln
Ricoh Super 8 800z Film Cartridge Hooks Replacement
Was du brauchst
  1. Ricoh Super 8 800z Film Cartridge Hooks Replacement, Film Cartridge Hooks: Schritt 1, Bild 1 von 3 Ricoh Super 8 800z Film Cartridge Hooks Replacement, Film Cartridge Hooks: Schritt 1, Bild 2 von 3 Ricoh Super 8 800z Film Cartridge Hooks Replacement, Film Cartridge Hooks: Schritt 1, Bild 3 von 3
    • Open the device's film cartridge door by pulling the release switch towards the eyepiece.
    • Lay the device with the left side down and the door open to allow access to the film cartridge hooks.
  2. Ricoh Super 8 800z Film Cartridge Hooks Replacement: Schritt 2, Bild 1 von 3 Ricoh Super 8 800z Film Cartridge Hooks Replacement: Schritt 2, Bild 2 von 3 Ricoh Super 8 800z Film Cartridge Hooks Replacement: Schritt 2, Bild 3 von 3
    • Using a Phillips #000 screwdriver, remove one of the screws from the rotating hooks in the center of the film bay.
    • Be sure to hold down the opposite side of the hooks with a finger to prevent it from spinning.
  3. Ricoh Super 8 800z Film Cartridge Hooks Replacement: Schritt 3, Bild 1 von 2 Ricoh Super 8 800z Film Cartridge Hooks Replacement: Schritt 3, Bild 2 von 2
    • Now put your finger on the side of the screw you just removed, and take out the remaining screw with a Phillips #000 screwdriver.
  4. Ricoh Super 8 800z Film Cartridge Hooks Replacement: Schritt 4, Bild 1 von 2 Ricoh Super 8 800z Film Cartridge Hooks Replacement: Schritt 4, Bild 2 von 2
    • Using your fingers, gently remove the film cartridge hooks.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 222
