Zum Hauptinhalt wechseln
Ricoh Theta S Outer Case Replacement
Was du brauchst
  1. Ricoh Theta S Outer Case Replacement, Outer Case: Schritt 1, Bild 1 von 1
    • Wedge the spudger underneath the small plastic square located on the bottom of the device.
    • Move the spudger to remove the plastic cover.
  2. Ricoh Theta S Outer Case Replacement: Schritt 2, Bild 1 von 2 Ricoh Theta S Outer Case Replacement: Schritt 2, Bild 2 von 2
    • Remove the four 3-mm screws located on the bottom of the device. You will need to use the Phillips 00 screwdriver.
  3. Ricoh Theta S Outer Case Replacement: Schritt 3, Bild 1 von 3 Ricoh Theta S Outer Case Replacement: Schritt 3, Bild 2 von 3 Ricoh Theta S Outer Case Replacement: Schritt 3, Bild 3 von 3
    • Insert the plastic opening tool in between the panels shown.
    • Apply pressure to unlatch the 9 spring clips located around the perimeter of the device.
    • Lift the panel from the device.
Abschluss
Bradley Sutton
737 Reputation
4 Anleitungen geschrieben
IUPUI, Team S3-G1, Harley Fall 2017 Mitglied von IUPUI, Team S3-G1, Harley Fall 2017
IUPUI-HARLEY-F17S3G1
3 Mitglieder
Ein Kommentar
Where can find spare part case?
Thanks
Franco - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 2,114
