Einleitung
This process involves removing the back cover, front cover, and various other camera components. Once done, the button mechanism can be removed.
Was du brauchst
Unscrew the seven indicated screws from the left, right, bottom, and back sides of the camera.
Open the film compartment.
Press your finger on top of the grey latch on the left side of the camera.
Use a thin object like a toothpick or a small screwdriver to push down on the metal pin holding the film compartment door in place.
Use your fingers to completely remove the metal pin.
Remove the film compartment door.
Using a thin shaft screwdriver, unscrew the two indicated screws within the film compartment.
Loosen the front cover from the left and right sides of the camera.
Remove the front cover.
Remove and set the front and back covers aside
Remove the screw that holds the front plate brace in place.
Remove brace.
Unscrew the four screws keeping the front face plate in place.
Remove metal clip.
After removing the metal clip in the previous step, the front face plate can be removed.
Unscrew the two screws that hold the button mechanism in place.
Press down on button mechanism to unlatch it from the camera body. When pressed down, the bottom of the mechanism should push outward.
Lift the button mechanism up carefully, removing the spring at the top of the mechanism from where it is attached to the camera body.
Remove the button mechanism.
