Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This process involves removing the back cover and the front cover of the camera.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Unscrew the seven indicated screws from the left, right, bottom, and back sides of the camera. Unscrew the seven indicated screws from the left, right, bottom, and back sides of the camera.
    • Unscrew the seven indicated screws from the left, right, bottom, and back sides of the camera.
  2. Loosen the back cover from both the left and the right sides of the camera. Remove back cover. The lid of the battery compartment may fall off because it is not attached to anything. Remove back cover. The lid of the battery compartment may fall off because it is not attached to anything.
    • Loosen the back cover from both the left and the right sides of the camera.
    • Remove back cover. The lid of the battery compartment may fall off because it is not attached to anything.
  3. Open the film compartment. Press your finger on top of the grey latch on the left side of the camera. Press your finger on top of the grey latch on the left side of the camera.
    • Open the film compartment.
    • Press your finger on top of the grey latch on the left side of the camera.
  4. Removing the film compartment door is optional. However, it may aid maneuverability in future steps. Use a thin object like a toothpick or a small screwdriver to push down on the metal pin holding the film compartment door in place. Use your fingers to completely remove the metal pin.
    • Removing the film compartment door is optional. However, it may aid maneuverability in future steps.
    • Use a thin object like a toothpick or a small screwdriver to push down on the metal pin holding the film compartment door in place.
    • Use your fingers to completely remove the metal pin.
    • Remove the film compartment door.
  5. Using a thin shaft screwdriver, unscrew the two indicated screws within the film compartment. Using a thin shaft screwdriver, unscrew the two indicated screws within the film compartment.
    • Using a thin shaft screwdriver, unscrew the two indicated screws within the film compartment.
  6. Loosen the front cover from the left and right sides of the camera. Remove the front cover. Remove the front cover.
    • Loosen the front cover from the left and right sides of the camera.
    • Remove the front cover.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Eric Dazet
352 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 6-21, Amido Spring 2012 Mitglied von Cal Poly, Team 6-21, Amido Spring 2012
CPSU-AMIDO-S12S6G21
4 Mitglieder
18 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 3
Insgesamt: 311
