Zum Hauptinhalt wechseln
Ricoh YF-20 Super Lens Cover Replacement
Was du brauchst
  1. Ricoh YF-20 Super Lens Cover Replacement, Front Cover: Schritt 1, Bild 1 von 2 Ricoh YF-20 Super Lens Cover Replacement, Front Cover: Schritt 1, Bild 2 von 2
    • Unscrew the seven indicated screws from the left, right, bottom, and back sides of the camera.
  2. Ricoh YF-20 Super Lens Cover Replacement: Schritt 2, Bild 1 von 3 Ricoh YF-20 Super Lens Cover Replacement: Schritt 2, Bild 2 von 3 Ricoh YF-20 Super Lens Cover Replacement: Schritt 2, Bild 3 von 3
    • Loosen the back cover from both the left and the right sides of the camera.
    • Remove back cover. The lid of the battery compartment may fall off because it is not attached to anything.
  3. Ricoh YF-20 Super Lens Cover Replacement: Schritt 3, Bild 1 von 3 Ricoh YF-20 Super Lens Cover Replacement: Schritt 3, Bild 2 von 3 Ricoh YF-20 Super Lens Cover Replacement: Schritt 3, Bild 3 von 3
    • Open the film compartment.
    • Press your finger on top of the grey latch on the left side of the camera.
  4. Ricoh YF-20 Super Lens Cover Replacement: Schritt 4, Bild 1 von 3 Ricoh YF-20 Super Lens Cover Replacement: Schritt 4, Bild 2 von 3 Ricoh YF-20 Super Lens Cover Replacement: Schritt 4, Bild 3 von 3
    • Removing the film compartment door is optional. However, it may aid maneuverability in future steps.
    • Use a thin object like a toothpick or a small screwdriver to push down on the metal pin holding the film compartment door in place.
    • Use your fingers to completely remove the metal pin.
    • Remove the film compartment door.
  5. Ricoh YF-20 Super Lens Cover Replacement: Schritt 5, Bild 1 von 2 Ricoh YF-20 Super Lens Cover Replacement: Schritt 5, Bild 2 von 2
    • Using a thin shaft screwdriver, unscrew the two indicated screws within the film compartment.
  6. Ricoh YF-20 Super Lens Cover Replacement: Schritt 6, Bild 1 von 3 Ricoh YF-20 Super Lens Cover Replacement: Schritt 6, Bild 2 von 3 Ricoh YF-20 Super Lens Cover Replacement: Schritt 6, Bild 3 von 3
    • Loosen the front cover from the left and right sides of the camera.
    • Remove the front cover.
  7. Ricoh YF-20 Super Lens Cover Replacement, Lens Cover: Schritt 7, Bild 1 von 3 Ricoh YF-20 Super Lens Cover Replacement, Lens Cover: Schritt 7, Bild 2 von 3 Ricoh YF-20 Super Lens Cover Replacement, Lens Cover: Schritt 7, Bild 3 von 3
    • The lens cover is only attached to the front cover of the camera. Set the rest of the camera aside.
    • In order to reach the lens cover, the zoom mechanism must be removed.
    • Unscrew three screws from the front cover that hold the zoom mechanism in place.
    • Remove the zoom mechanism.
  8. Ricoh YF-20 Super Lens Cover Replacement: Schritt 8, Bild 1 von 3 Ricoh YF-20 Super Lens Cover Replacement: Schritt 8, Bild 2 von 3 Ricoh YF-20 Super Lens Cover Replacement: Schritt 8, Bild 3 von 3
    • Unscrew the five screws that hold the lens cover plate and metal brace in place.
    • Remove metal brace.
    • Remove lens cover plate.
  9. Ricoh YF-20 Super Lens Cover Replacement: Schritt 9, Bild 1 von 2 Ricoh YF-20 Super Lens Cover Replacement: Schritt 9, Bild 2 von 2
    • To remove lens cover, push the lens cover from the outside of the front cover towards the inside of the front cover.
    • Remove the lens cover.
    • The metal arm attached to the lens cover is not securely attached and may fall off.
Abschluss
Eric Dazet
352 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 6-21, Amido Spring 2012 Mitglied von Cal Poly, Team 6-21, Amido Spring 2012
CPSU-AMIDO-S12S6G21
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 292
