Einleitung
This replacement guide will walk you through how to remove and replace the two carbon brushes. You may also find this guide useful if you need to inspect the carbon brush housing for debris that may be hindering the device's performance.
Was du brauchst
Using your fingers, gently lift the carbon brush up and out of its housing.
Repeat these steps to remove the other carbon brush on the opposing side.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
