Zum Hauptinhalt wechseln
Ridgid Angle Grinder R10202 Disk Guard Spring Replacement
Was du brauchst
  1. Ridgid Angle Grinder R10202 Disk Guard Spring Replacement, Disk Guard Spring: Schritt 1, Bild 1 von 1
    • Unscrew the clamp nut and the backing flange from the output shaft assembly.
    • You can do this by hand or use a spanner wrench which should be provided in the manufacturers box.
  2. Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: Schritt 2, Bild 1 von 2 Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: Schritt 2, Bild 2 von 2
    • Push in the guard lever and twist the guard until it aligns with the slots on the output shaft assembly.
    • There are two arrows that should align before you attempt to pull the pieces apart.
  3. Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: Schritt 3, Bild 1 von 2 Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: Schritt 3, Bild 2 von 2
    • Unscrew the 5 M5 X 10mm screws using a Torx T20 Bit.
    • Carefully separate the spacer from the guard.
  4. Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: Schritt 4, Bild 1 von 2 Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: Schritt 4, Bild 2 von 2
    • Gently push the spring away from the spacer.
    • The spacer, spring, and guard lever should now be all separate.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 728
