Einleitung
Inspection of the motor housing is an important step in determining damage to the inner workings of the grinder. Visual inspection or repair of the gear housing, or "V" motor assembly, will require this guide.
Was du brauchst
Using your fingers, gently lift the carbon brush up and out of its housing.
Repeat these steps to remove the other carbon brush on the opposing side.
Unscrew the side handle assembly from the gear housing assembly by hand.
Push in the guard lever and twist the guard until it aligns with the slots on the output shaft assembly.
There are two arrows that should align before you attempt to pull the pieces apart.
Grab the handle assembly and the gear housing assembly and gently pull apart.
Slowly pull the gear housing assembly out being careful not to damage the motor against the inside of the motor housing.
