Zum Hauptinhalt wechseln
Ridgid Angle Grinder R10202 Motor Housing Replacement
Was du brauchst
  1. Ridgid Angle Grinder R10202 Motor Housing Replacement, Carbon Brush: Schritt 1, Bild 1 von 2 Ridgid Angle Grinder R10202 Motor Housing Replacement, Carbon Brush: Schritt 1, Bild 2 von 2
    • Use a flathead screwdriver to unscrew the brush holder cap.
  2. Ridgid Angle Grinder R10202 Motor Housing Replacement: Schritt 2, Bild 1 von 2 Ridgid Angle Grinder R10202 Motor Housing Replacement: Schritt 2, Bild 2 von 2
    • Using your fingers, gently lift the carbon brush up and out of its housing.
    • Repeat these steps to remove the other carbon brush on the opposing side.
  3. Ridgid Angle Grinder R10202 Motor Housing Replacement, Motor Housing: Schritt 3, Bild 1 von 1
    • Unscrew the side handle assembly from the gear housing assembly by hand.
  4. Ridgid Angle Grinder R10202 Motor Housing Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the clamp nut and the backing flange from the output shaft assembly.
    • You can do this by hand or use a spanner wrench which should be provided in the manufacturers box.
  5. Ridgid Angle Grinder R10202 Motor Housing Replacement: Schritt 5, Bild 1 von 2 Ridgid Angle Grinder R10202 Motor Housing Replacement: Schritt 5, Bild 2 von 2
    • Push in the guard lever and twist the guard until it aligns with the slots on the output shaft assembly.
    • There are two arrows that should align before you attempt to pull the pieces apart.
  6. Ridgid Angle Grinder R10202 Motor Housing Replacement: Schritt 6, Bild 1 von 1
    • Lift the guard away from the output shaft assembly.
  7. Ridgid Angle Grinder R10202 Motor Housing Replacement: Schritt 7, Bild 1 von 2 Ridgid Angle Grinder R10202 Motor Housing Replacement: Schritt 7, Bild 2 von 2
    • Using a T25 Torx screwdriver, unscrew the four M5 X 28mm Torx screws.
  8. Ridgid Angle Grinder R10202 Motor Housing Replacement: Schritt 8, Bild 1 von 3 Ridgid Angle Grinder R10202 Motor Housing Replacement: Schritt 8, Bild 2 von 3 Ridgid Angle Grinder R10202 Motor Housing Replacement: Schritt 8, Bild 3 von 3
    • Grab the handle assembly and the gear housing assembly and gently pull apart.
    • Slowly pull the gear housing assembly out being careful not to damage the motor against the inside of the motor housing.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 801
