Zum Hauptinhalt wechseln
Ridgid Angle Grinder R10202 Wiring Assembly Replacement
Was du brauchst
  1. Ridgid Angle Grinder R10202 Wiring Assembly Replacement, Wiring Assembly: Schritt 1, Bild 1 von 2 Ridgid Angle Grinder R10202 Wiring Assembly Replacement, Wiring Assembly: Schritt 1, Bild 2 von 2
    • Take hold of the Side Assembly Handle [8] and unscrew to detach from the grinder.
  2. Ridgid Angle Grinder R10202 Wiring Assembly Replacement: Schritt 2, Bild 1 von 1
    • To get to the guard, unscrew and remove the Clamp Nut [34], Grinding Wheel (not pictured) [35], and Backing Flange [36].
  3. Ridgid Angle Grinder R10202 Wiring Assembly Replacement: Schritt 3, Bild 1 von 1
    • To remove the Guard [38], press and hold the Guard Lever [39] and rotate the head to line up the two arrows inlayed within the metal as seen in the photograph provided.
    • Once the arrows line up lift the Guard [38] from the grinder.
  4. Ridgid Angle Grinder R10202 Wiring Assembly Replacement: Schritt 4, Bild 1 von 3 Ridgid Angle Grinder R10202 Wiring Assembly Replacement: Schritt 4, Bild 2 von 3 Ridgid Angle Grinder R10202 Wiring Assembly Replacement: Schritt 4, Bild 3 von 3
    • Use TORX T20 Screwdriver to unscrew and remove 5 M5 x 16 mm, TORX Screws [28].
    • Use TORX T20 Screwdriver to unscrew and remove 1 M5 x 28 mm, TORX Screw [1].
    • Use TORX T10 Screwdriver to unscrew and remove 1 M3 x 10 mm Screw [26].
  5. Ridgid Angle Grinder R10202 Wiring Assembly Replacement: Schritt 5, Bild 1 von 2 Ridgid Angle Grinder R10202 Wiring Assembly Replacement: Schritt 5, Bild 2 von 2
    • You should now be able to separate each side of the Handle Assembly [27] as seen in the first photograph.
    • Remove the side that should easily separate from the other.
    • One side will remain as seen in the second picture as it is still screwed in.
  6. Ridgid Angle Grinder R10202 Wiring Assembly Replacement: Schritt 6, Bild 1 von 3 Ridgid Angle Grinder R10202 Wiring Assembly Replacement: Schritt 6, Bild 2 von 3 Ridgid Angle Grinder R10202 Wiring Assembly Replacement: Schritt 6, Bild 3 von 3
    • Use a Hex Screwdriver to unscrew and remove the 2 8-16 x 1/2 in. Screws [29].
  7. Ridgid Angle Grinder R10202 Wiring Assembly Replacement: Schritt 7, Bild 1 von 1
    • The Cord Clamp [30] should be easily removed as seen separated from the Power Cord [32].
  8. Ridgid Angle Grinder R10202 Wiring Assembly Replacement: Schritt 8, Bild 1 von 3 Ridgid Angle Grinder R10202 Wiring Assembly Replacement: Schritt 8, Bild 2 von 3 Ridgid Angle Grinder R10202 Wiring Assembly Replacement: Schritt 8, Bild 3 von 3
    • Use a screwdriver to unscrew and remove 1 M4 x 14 mm Screw [23].
  9. Ridgid Angle Grinder R10202 Wiring Assembly Replacement: Schritt 9, Bild 1 von 3 Ridgid Angle Grinder R10202 Wiring Assembly Replacement: Schritt 9, Bild 2 von 3 Ridgid Angle Grinder R10202 Wiring Assembly Replacement: Schritt 9, Bild 3 von 3
    • The whole wiring assembly should be able to be lifted out of where it currently is as seen in the first photograph.
    • Allow the wiring assembly to hang from the grinder as seen in the second picture.
    • Press and hold the Handle Lock Button [24] to release the second side of the Handle Assembly [27].
  10. Ridgid Angle Grinder R10202 Wiring Assembly Replacement: Schritt 10, Bild 1 von 3 Ridgid Angle Grinder R10202 Wiring Assembly Replacement: Schritt 10, Bild 2 von 3 Ridgid Angle Grinder R10202 Wiring Assembly Replacement: Schritt 10, Bild 3 von 3
    • Use screwdriver to unscrew 4 M3.5 x 7 mm Screws [22].
    • The Switch [21], Power Cord [32], and Motor Housing [11] should now all be separated as seen in the third photograph.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Be careful while jointing the wires because it can cause you some electric issues for more info you can read this guide.
Fahed - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 16
Insgesamt: 1,298
