Einleitung
Use this guide to replace the forward/reverse switch in your Ridgid 860054 Drill.
The forward/reverse switch is also known as the rocker switch.
The forward/reverse switch allows you to change the direction in which your drill rotates. If it is damaged or otherwise unusable, you will be unable to change the direction of rotation of the drill.
Though unlikely, there may be other issues interfering with the function of the forward/reverse switch. Make sure to visit the troubleshooting guide before proceeding with the repair.
Was du brauchst
Using a T10 Torx security bit, remove the ten screws from the housing assembly.
Separate one half of the drill casing from the other by gently pulling both halves apart.
Remove the plastic speed switch and forward/reverse switch by softly lifting them from the casing.
Remove the internal components of the drill by lightly pulling on the drill chuck.
Remove the broken forward and backward switch by lifting it off of the trigger.
Eine weitere Person hat diese Anleitung absolviert.
