Zum Hauptinhalt wechseln
Ridgid GEN5X R8611506 Light Switch Replacement
Was du brauchst
  1. Ridgid GEN5X R8611506 Light Switch Replacement, Outer Case: Schritt 1, Bild 1 von 2 Ridgid GEN5X R8611506 Light Switch Replacement, Outer Case: Schritt 1, Bild 2 von 2
    • Orient the drill to have the side with the screws facing up.
    • Using the Torx T10 screwdriver, remove the eight 4.0mm screws from the face of the drill.
  2. Ridgid GEN5X R8611506 Light Switch Replacement: Schritt 2, Bild 1 von 3 Ridgid GEN5X R8611506 Light Switch Replacement: Schritt 2, Bild 2 von 3 Ridgid GEN5X R8611506 Light Switch Replacement: Schritt 2, Bild 3 von 3
    • Orient the drill to where the back is facing up.
    • Using a Torx T10 screwdriver, remove the four 6.0mm screws that attach the back piece to the drill.
    • Remove the back piece of the drill using the iFixit opening tool.
  3. Ridgid GEN5X R8611506 Light Switch Replacement: Schritt 3, Bild 1 von 2 Ridgid GEN5X R8611506 Light Switch Replacement: Schritt 3, Bild 2 von 2
    • Orient the drill to where the chuck is facing up.
    • Using the Torx T15 screwdriver, remove the four 8.0mm screws from the front of the drill.
  4. Ridgid GEN5X R8611506 Light Switch Replacement: Schritt 4, Bild 1 von 2 Ridgid GEN5X R8611506 Light Switch Replacement: Schritt 4, Bild 2 von 2
    • Orient the drill so the side with the screw holes is facing up.
    • Use a plastic opening tool to gently pry the face off of the drill.
    • Remove the face completely from the drill.
  5. Ridgid GEN5X R8611506 Light Switch Replacement, Light Switch: Schritt 5, Bild 1 von 2 Ridgid GEN5X R8611506 Light Switch Replacement, Light Switch: Schritt 5, Bild 2 von 2
    • Locate the light switch near the bottom of the drill's inner components.
    • Gently remove the light switch from the casing.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 373
