Zum Hauptinhalt wechseln
Ridgid GEN5X R8642 Gear Assembly Replacement
Was du brauchst
  1. Ridgid GEN5X R8642 Gear Assembly Replacement, Gear Assembly: Schritt 1, Bild 1 von 1
    • Remove the plastic tab holding the handle cover in place by prying upward with the spudger until the tab pops off.
  2. Ridgid GEN5X R8642 Gear Assembly Replacement: Schritt 2, Bild 1 von 1
    • Remove the handle cover by pulling it towards the front of the saw.
    • The grip can sometimes become stuck and may require a decent amount of force to remove.
  3. Ridgid GEN5X R8642 Gear Assembly Replacement: Schritt 3, Bild 1 von 2 Ridgid GEN5X R8642 Gear Assembly Replacement: Schritt 3, Bild 2 von 2
    • Use a T20 Torx screwdriver to remove the nine M4 X 16mm screws from the plastic housing.
  4. Ridgid GEN5X R8642 Gear Assembly Replacement: Schritt 4, Bild 1 von 1
    • Use a JIS #1 screwdriver to remove the two M4 x 25mm screws on both sides of the metal housing.
  5. Ridgid GEN5X R8642 Gear Assembly Replacement: Schritt 5, Bild 1 von 1
    • Remove one half of the plastic housing using a spudger so that the internal system is exposed.
  6. Ridgid GEN5X R8642 Gear Assembly Replacement: Schritt 6, Bild 1 von 2 Ridgid GEN5X R8642 Gear Assembly Replacement: Schritt 6, Bild 2 von 2
    • Remove the one 16mm T20 screw that holds the grip support onto the saw.
  7. Ridgid GEN5X R8642 Gear Assembly Replacement: Schritt 7, Bild 1 von 3 Ridgid GEN5X R8642 Gear Assembly Replacement: Schritt 7, Bild 2 von 3 Ridgid GEN5X R8642 Gear Assembly Replacement: Schritt 7, Bild 3 von 3
    • Remove the five T20 Torx screws from the gear assembly cover and pull the cover off.
  8. Ridgid GEN5X R8642 Gear Assembly Replacement: Schritt 8, Bild 1 von 2 Ridgid GEN5X R8642 Gear Assembly Replacement: Schritt 8, Bild 2 von 2
    • Carefully remove the motor making sure not to harm any of the wires that are attached. Place motor gently out of the way.
  9. Ridgid GEN5X R8642 Gear Assembly Replacement: Schritt 9, Bild 1 von 3 Ridgid GEN5X R8642 Gear Assembly Replacement: Schritt 9, Bild 2 von 3 Ridgid GEN5X R8642 Gear Assembly Replacement: Schritt 9, Bild 3 von 3
    • Remove the orbital switch by pulling straight up on it.
    • Be careful to not lose the spring and pin that is inside of the switch.
  10. Ridgid GEN5X R8642 Gear Assembly Replacement: Schritt 10, Bild 1 von 3 Ridgid GEN5X R8642 Gear Assembly Replacement: Schritt 10, Bild 2 von 3 Ridgid GEN5X R8642 Gear Assembly Replacement: Schritt 10, Bild 3 von 3
    • Remove the gear assembly by pulling it straight up.
  11. Ridgid GEN5X R8642 Gear Assembly Replacement: Schritt 11, Bild 1 von 3 Ridgid GEN5X R8642 Gear Assembly Replacement: Schritt 11, Bild 2 von 3 Ridgid GEN5X R8642 Gear Assembly Replacement: Schritt 11, Bild 3 von 3
    • Pull the pin holding the metal guide housing in place.
    • Slide the metal guide housing back off the gear assembly.
  12. Ridgid GEN5X R8642 Gear Assembly Replacement: Schritt 12, Bild 1 von 2 Ridgid GEN5X R8642 Gear Assembly Replacement: Schritt 12, Bild 2 von 2
    • Remove the guide bushing by pulling up on it.
    • Then slide the pin out that holds the gear assembly and blade clamp assembly.
  13. Ridgid GEN5X R8642 Gear Assembly Replacement: Schritt 13, Bild 1 von 1
    • Slide the blade clamp assembly off the gear assembly.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
When reassembling with new gear, does gear needs to be greased?
Syoma Zv - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 30
Insgesamt: 1,993
