Zum Hauptinhalt wechseln
Ridgid GEN5X R8653 Base Assembly Replacement
Was du brauchst
  1. Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: Schritt 1, Bild 1 von 3 Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: Schritt 1, Bild 2 von 3 Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: Schritt 1, Bild 3 von 3
    • Always disconnect battery and use gloves when working with the saw blade. Failure to do so may result in damage or injury!
    • Remove the supplied Allen wrench from it's nesting space in the front of the handle.
    • Depress and hold the spindle lock button located between the handle and blade shroud.
    • Using the supplied 6mm Allen Wrench, unscrew the bolt securing the blade and remove the blade.
  2. Ridgid GEN5X R8653 Base Assembly Replacement: Schritt 2, Bild 1 von 3 Ridgid GEN5X R8653 Base Assembly Replacement: Schritt 2, Bild 2 von 3 Ridgid GEN5X R8653 Base Assembly Replacement: Schritt 2, Bild 3 von 3
    • Remove seven 6mm T20 Torx screws located around base of saw.
    • Pull base assembly away from saw.
    • These screws are very tight and need significant force to be removed.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 218
