Zum Hauptinhalt wechseln
Ridgid JobMax R2851 Series B Directional Button Replacement
Was du brauchst
  1. Ridgid JobMax R2851 Series B Directional Button Replacement, Directional Button: Schritt 1, Bild 1 von 2 Ridgid JobMax R2851 Series B Directional Button Replacement, Directional Button: Schritt 1, Bild 2 von 2
    • Unplug the device from the wall.
    • Orient the device so that the trigger is facing downwards.
    • Place your thumb and index finger on the two buttons located on the head of the tool.
    • Press the two buttons in and pull the head of the tool off.
  2. Ridgid JobMax R2851 Series B Directional Button Replacement: Schritt 2, Bild 1 von 1
    • Loosen all eight 15mm T10 Torx screws.
    • You do not need to fully remove the screws yet; just loosen them enough that the device shell starts to open.
  3. Ridgid JobMax R2851 Series B Directional Button Replacement: Schritt 3, Bild 1 von 1
    • Orient the device so that the cord end is facing upwards.
    • Take a small cutting tool, and cut down the seam in the back, ensuring that you only cut the sticker.
    • Make a shallow cut to avoid damaging internal hardware.
  4. Ridgid JobMax R2851 Series B Directional Button Replacement: Schritt 4, Bild 1 von 2 Ridgid JobMax R2851 Series B Directional Button Replacement: Schritt 4, Bild 2 von 2
    • Completely remove all eight 15mm T10 Torx screws.
  5. Ridgid JobMax R2851 Series B Directional Button Replacement: Schritt 5, Bild 1 von 3 Ridgid JobMax R2851 Series B Directional Button Replacement: Schritt 5, Bild 2 von 3 Ridgid JobMax R2851 Series B Directional Button Replacement: Schritt 5, Bild 3 von 3
    • Pull the device case off, gripping at the back of the case and rotating it towards the front of the device.
    • Once the device has been separated gently pull on the trigger assembly to remove it from one side of the case.
    • Watch out for the locking mechanism for the head of the device when removing.
  6. Ridgid JobMax R2851 Series B Directional Button Replacement: Schritt 6, Bild 1 von 1
    • Grab the trigger mechanism, and lift it up and away from the device.
    • Be gentle when lifting it out—it is still attached by short wires.
  7. Ridgid JobMax R2851 Series B Directional Button Replacement: Schritt 7, Bild 1 von 2 Ridgid JobMax R2851 Series B Directional Button Replacement: Schritt 7, Bild 2 von 2
    • Slide and wiggle the metal rod holding down the directional button.
    • This rod is connected by two small holes in the directional button so moving up and to the right is the best.
  8. Ridgid JobMax R2851 Series B Directional Button Replacement: Schritt 8, Bild 1 von 2 Ridgid JobMax R2851 Series B Directional Button Replacement: Schritt 8, Bild 2 von 2
    • Slide the directional button up and out of the device.
    • Hole and slot for reassembly
    • After the button is replaced, the metal rod fits into a small hole and slot to the right of the button. The tiny spring has to be slid over to set it in place.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 599
