Einleitung
The Ridgid JobMax R8620 Series E has a built in LED light on the right side of the device. If the light is dim or not turning on, then you might need to replace the LED light. This guide will give you step-by-step instructions on how to replace the LED light.
Was du brauchst
Pull the battery out of the case by hand before opening the device.
Using a Torx T10 screwdriver, remove the nine 6mm screws on the drill cover.
Lift off the outer casing.
Using a spudger or your fingers, remove the LED light from the groove in the handle.
Find the corresponding position of the LED line on the motherboard. If necessary, use tweezers to pull it out and replace it.
