Zum Hauptinhalt wechseln
Ridgid R2601 Motor Assembly Replacement
Was du brauchst
  1. Ridgid R2601 Motor Assembly Replacement, Top Cover: Schritt 1, Bild 1 von 1
    • Remove the four M3.5 x 16 mm screws from the top cover using a Torx T10 screwdriver.
  2. Ridgid R2601 Motor Assembly Replacement: Schritt 2, Bild 1 von 1
    • Pull off the top cover.
  3. Ridgid R2601 Motor Assembly Replacement, Bearing: Schritt 3, Bild 1 von 1
    • Turn the sander upside down so that the base faces you.
    • Remove the four 6.4 mm screws from the bottom of the base using a Torx T-25 screwdriver.
  4. Ridgid R2601 Motor Assembly Replacement: Schritt 4, Bild 1 von 1
    • Remove the base.
  5. Ridgid R2601 Motor Assembly Replacement: Schritt 5, Bild 1 von 1
    • Remove the 10 mm screw from the center of the bearing using a Torx T-20 screwdriver.
  6. Ridgid R2601 Motor Assembly Replacement: Schritt 6, Bild 1 von 1
    • Remove the bearing.
  7. Ridgid R2601 Motor Assembly Replacement, Brake: Schritt 7, Bild 1 von 1
    • Remove the four 16mm screws from the side of the sander using a Torx T20 screwdriver.
  8. Ridgid R2601 Motor Assembly Replacement: Schritt 8, Bild 1 von 1
    • Use a metal spudger to open the sander's plastic housing.
  9. Ridgid R2601 Motor Assembly Replacement: Schritt 9, Bild 1 von 1
    • Remove the plastic housing.
  10. Ridgid R2601 Motor Assembly Replacement: Schritt 10, Bild 1 von 1
    • Remove the brake from its slot in the housing.
  11. Ridgid R2601 Motor Assembly Replacement, Motor Assembly: Schritt 11, Bild 1 von 1
    • Remove the metal flywheel.
  12. Ridgid R2601 Motor Assembly Replacement: Schritt 12, Bild 1 von 1
    • Rotate the sander so that the top is facing you.
    • Remove the power switch.
  13. Ridgid R2601 Motor Assembly Replacement: Schritt 13, Bild 1 von 2 Ridgid R2601 Motor Assembly Replacement: Schritt 13, Bild 2 von 2
    • Use a T20 Torx screwdrivers to remove the four 11.11mm screws from the motor housing.
    • Use a T25 Torx screwdriver to remove the two 12.7mm screws next to the leads.
  14. Ridgid R2601 Motor Assembly Replacement: Schritt 14, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Kaufen
    • Use a 2.5mm flathead screwdriver to loosen but not remove the screws holding the wiring leading to the speed controller.
  15. Ridgid R2601 Motor Assembly Replacement: Schritt 15, Bild 1 von 1
    • Remove the leads.
  16. Ridgid R2601 Motor Assembly Replacement: Schritt 16, Bild 1 von 1
    • Remove the motor housing.
  17. Ridgid R2601 Motor Assembly Replacement: Schritt 17, Bild 1 von 1
    • Remove the motor.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 917
