Einleitung
In this guide, we will replace the motor in the Rigid R2601 orbital sander. This part is often subject to damage because it is a moving part and can burn up, rendering the sander useless. Before starting this guide, please unplug and turn off the sander.
Was du brauchst
Remove the four M3.5 x 16 mm screws from the top cover using a Torx T10 screwdriver.
Turn the sander upside down so that the base faces you.
Remove the four 6.4 mm screws from the bottom of the base using a Torx T-25 screwdriver.
Remove the 10 mm screw from the center of the bearing using a Torx T-20 screwdriver.
Remove the four 16mm screws from the side of the sander using a Torx T20 screwdriver.
Use a T20 Torx screwdrivers to remove the four 11.11mm screws from the motor housing.
Use a T25 Torx screwdriver to remove the two 12.7mm screws next to the leads.
Use a 2.5mm flathead screwdriver to loosen but not remove the screws holding the wiring leading to the speed controller.
2 weitere Personen haben diese Anleitung absolviert.
