Einleitung
If you are not able to change the speed settings on your sander, the speed dial is probably at fault. The dial can become worn down, meaning that it needs to be replaced. Make sure that the sander is unplugged when completing this replacement.
Was du brauchst
Remove the four M3.5 x 16 mm screws from the top cover using a Torx T10 screwdriver.
Remove the orange speed dial simply by pulling it out using your hands.
Fast fertig!
Abschluss
