Einleitung
The trigger mechanism can jam or become less responsive overtime. This is due to over use.
Was du brauchst
Remove the seven 2.5 mm screws on the top of the sander using the Torx T15 screwdriver.
Use the screwdriver to unscrew the two #6-19 X 5/8 in screws holding down the outlet cord.
Using the screwdrivers, unscrew the four #6-19 X 5/8 in screws on rectangular block.
3 weitere Personen haben diese Anleitung absolviert.
